Front brakes locked and rear drag
Old Nov 17, 2025 | 11:08 AM
D3rek1911's Avatar
Hey, I got a 91 RS Camaro, I just installed D52 Wilwood calipers on the rear and replaced the front two with OEM calipers. Now I'm running into the issue of my front calipers being completely locked after bleeding and the rear calipers are dragging. I replaced the master cylinder and that didn't help. Any advice is much appreciated, thank you.
Old Nov 17, 2025 | 11:16 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Front brakes locked and rear drag
Sounds like a proportioning valve issue
Old Nov 17, 2025 | 11:18 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Are the brake hoses original? If so, they may need replaced.
Did the prop valve valve shift offcenter when bleeding?
Old Nov 17, 2025 | 05:35 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Old hoses was my first thought.
Old Nov 22, 2025 | 09:20 AM
Beeman's Avatar
When the fronts are locked crack the bleeder and see if they release. If it releases pump the brakes again and get them to lock, now crack the line at the MC and see if they release. This will isolate where the pressure is being held.
someone972
Brakes
May 25, 2017 10:10 PM
NinjaNife
Brakes
18
Jan 21, 2014 08:40 AM
kammi10
Brakes
Apr 1, 2012 01:33 PM
Theman0188
Feb 10, 2008 10:12 PM
vwdave
Feb 9, 2004 11:02 AM
