Capping Brake Hose at Disk Brake
Car: 1984 Trans AM
Transmission: 700-4r
I will be removing the calipers from my '84 T/A.
What have u guys used to cap the brake hose end at the caliper connection?
I have some black rubber caps that i purchased years ago, but not certain if they will fit.
tried to post picture but for some reason system would not let me.
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Capping Brake Hose at Disk Brake
me, i put the hose into a water bottle and let it drain out.
Anytime i do brake hoses, i always flush / bleed the system with new fluid.
Car: 89 PONTIAC TRANS AM
Engine: 5.0 TPI
Transmission: Stock 4SP 700R4
Axle/Gears: 4TH GEN 3:23
I work in parts at a dealership and I am always caught up on the newest tools from them or the tool trucks and these things are the hot new things to have. they are spring loaded rubber stoppers and they seam to work pretty good. I purchased a set myself and used them on my LS1 front brake upgrade and was able to keep my fluid mess to a minimum while I swapped the calipers and brass washers.
