[FL] 86 Camaro big block 496 6 spd roller u finish
Car: 1986 CAMARO Z28 +++
Engine: 496
Axle/Gears: 456
PACKAGE DEAL A MUST SEE *** I AM NOT WILLING TO SEPERATE AT THIS TIME ***
IF AND WHEN I DO I WILL POST SEPERATE ADS. THANKS FOR LOOKING ANY QUESTIONS PM ME
$9,500 cash only....only trade i would consider would be 2003 up z71 ext cab silverado
1986 CAMARO Z28
COMPLETE BODY RESTORED MINT MINT MINT
NEVER NO RUST AND I HAVE PICS TO SHOW BEFORE I STARTED THE RESTORE
BODY IS READY FOR PAINT NOW IN BLACK EPOXY PRIMER
FIREWALL SMOOTH OUT AC/HEAT DELETE
SHOCK TOWERS WELDED AND SMOOTH
NEW HARWOODFIBERGLASS BOLT ON 2 ½ IN COWL HOOD
NEW GM FRONT BUMPER COVER
NEW GM FRONT LOWER SPOILER GROUND EFFECT ( 91-92 YEAR STYLE)
92 Z28 STYLE TALL REAR SPOILER
POWER DOORS
FRONT FENDERS HAD THE MAKER LIGHTS SHAVED AND WELDED UP ALONG WITH ANT MOUNT HOLE
ENGINE
454 BORDED AND STROKED TO 496
ALL ROLLER MOTOR
ALL MACHINE WORK DONE BY SPEED SHOP IN TENN I CAN PROVIDE THERE # IF YOU WANT TO CALL THEM THEY KNOW THE MOTOR WELL
INTERNIAL BALLANCED
BORED AND HONED WITH DECK PLATES
LINE BORED
4 BOLT MAIN
BLOCK SHOT PEENED AND TANKED TWICE
BOTTON END ALL FORGED
10.2-1 COMP
EAGLE STROKER CRANK
EAGLE H-BEAM RODS FREE FLOATING
SRP PISTONS FLAT TOP 4 V-RELIEF
ALL KING BEARINGS
PROCOMP ALUMINUM HEADS
EVERYTHING WAS UPGRADED FOR THE SOLID ROLLER CAM
SPRINGS GOOD TO 750 LIFT FOR SOLID ROLLER
2.250 – 1.88 VALVES
320 CC REC PORT
HEADS AND INTAKE GASKET MATCHED
DOUG HERBERT SOLID ROLL CAM #BR235-110
685-685 LIFT 110 LOBE CENTER
PRO COMP SOLID ROLLER LIFTERS
I PIECE HARDENED PUSH RODS
DART ADJUSTABLE GUIDE PLATES
CRANE ROLLER ROCKERS
CARTER MANUAL HP FUEL PUMP
HP OIL PUMP
MANLLEY HUGE HD-HP ROLLER TIMING CHAIN
ALUMINUM TIMING CHAIN COVER
ALUMINUM POWER PLUS HURRICAN INTAKE
CHROME VALVE COVERS AND OIL PAN
PRO COMP HARMANIC BALLANCER
COMPOSITE CARB SPACER
PRO COMP BILLET DISTRIBUTER WITH MSD CAP
MSD 6AL BOX
HOOKER SUPER COMP HEADERS CERAMIC COATED
DUEL ELECTRIC FAN SET UP
EVERY MOTOR PART IS BRAND NEW NOTHING USED THE ONLY THING USED IS THE BLOCK BUT NOW IT’S BETER THEN NEW EVERY BOLT WAS REPALCE WITH ARP BOLTS
TRANSMISSION
T-56 6 SPEED OU OF A 97 CAMARO WITH BELLHOUSING
NEW CENTER FORCE FLYWHEEL CORRECT ONE FOR THIS BIGBLOCK AND TRANS 153 TOOTH
SUSPESION PARTS
SPOHN TORQE ARM
SPOHN T-56 CROSS MEMBER WITH DRIVE SHAFT LOOP
SPOHN TUBULAR A-ARMS WITH SPRING BOX’S
SPOHN TUBULAR K-MEMBER
JACK PLATES FRONT AND REAR LOWERS CAR THE RIGHT WAY
2 SETS OF SPRINGS FOR FRONT
1 SET OF SPRINGS FOR REAR
FULLY ADJUSTABLE SHOCK TOWER PLATES/CAMBER PLATES
CUSTOM MADE HEAVY DUTY FRAME CONNECTORS
INTERIOR I HAVE TONS OF INTERIOR PARTS
I KNOW THERES MORE TO ADD TO THIS LIST JUST CANT THINK OF EVERYTHING IF YOUR INTERESTED CALL ME OR EMAIL I HAVE ALOT OF PICS I CAN SEND..JUST ASK WHAT YOU WANT TO SEE
1986 CAMARO Z28
POWER DOORS
ENGINE
ALL ROLLER MOTOR
INTERNIAL BALLANCED
LINE BORED
4 BOLT MAIN
10.2-1 COMP
EAGLE STROKER CRANK
ALL KING BEARINGS
2.250 – 1.88 VALVES
320 CC REC PORT
HP OIL PUMP
MSD 6AL BOX
TRANSMISSION
SUSPESION PARTS
SPOHN TORQE ARM
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Re: 86 Camaro big block 496 6 spd roller u finish
Post some pics. It would help
