1987 Camaro project
Car: 1987 Camaro
Engine: 305 v8
1987 Camaro project
Regretfully I have to sell the project car I've been working on since I was 16. I spent alot of money on getting it to where it is today and made it so close to my dream but a bad carburetor crushed that dream. I built up a decent 350 with new heads, new upper internals and a bunch of goodies. The carb had a bad seal in it and ended up washing the cylinder walls with gasoline there by locking up the bottom end : - ( So after investing all my blood, sweat and tears, my loss is your gain. All it needs to run is a new bottom end, thats it. If youve got the means this is a great deal.
New Parts...
-Comp Cam (mild, a little lopey)
-Dart Iron eagle heads
-Roller tip rockers
-Headman headers and custom 2-1 exahaust with dynaflow muffler
-HEI ignition
-Plugs, wires and maintenance parts are fresh.
-Fuel pump, oil pump
-Starter
-Windshield
-T-top seals and weather stripping (not all of it)
-New carpet and floor panels
-700r4 from a 4th gen corvette, new filter, oil
-B&M torque converter 1500 stall
-oil pan and seals
-Has an IROC-Z black hood with "vents" could use some paint, new hood supports and latch
The bad, it doesnt run, you've gotta tow it. The carb is trash and has been pulled off. The body is in alright shape for the year but it is rough. Standard amount of rust. I cut and repaired the A-pillars a while back, needs to be painted. I never had it on the road long enough to asses the running condition of brakes and all the suspension. I did a new front caliper and pads some years ago. Nothing seems to leak or be unsafe from what I can tell. Comes with a custom audio system that came with the car. 2x12 custom box. Bass/ system amplifiers with custom EQ. Alpine CD head unit that should still work. Needs an ignition cylinder (can be started without key) and door hinges. Most of the interior stuff works to my knowledge. I have a few pics and can send more upon request.
I am asking 1500, my loss is your gain. Very sad to have to say goodbye to the project.
New Parts...
-Roller tip rockers
-HEI ignition
-Starter
-Windshield
-oil pan and seals
beachrodder
Aug 25, 2015 08:05 AM
