[NS] 84 Camaro Drag Car **Turn key**
Car: 1984 drag car and 1991 Z28 street
Engine: 406sbc
Transmission: powerglide
Axle/Gears: 5.14
1984 Camaro drag car
400 small block, powerglide, 12 bolt rear. Full roll cage. Back half 4 link with adjustable shocks. Front adjustable struts with coil over conversion. Tubular front cross member, with removable center to take the oil pan off easy. Front wilwood brakes. Weld SFI wheels. All steel car except the hood, lexan rear window. Trans brake, Dedenbear crossover delay box and Co2 start line controller/ throttle stop. Good car for NHRA/IHRA 10.90/ 9.90 classes.
Engine has aftermarket block with all good pieces, dyno sheets ect. Naturally aspirated with one carburetor. 2800lbs with 725hp. Stahl headers, ATI converter, BG fuel system.
Clean rust free body, been a race car since the late 80's. 2 races on new radials. Low runs on the engine.
More pictures and video available. Easy and fun to drive. Chassis and engine are well sorted out, and the car will easily stand on the rear bumper if you want it to.
Car has a title, but is currently NOT street legal.
Runs 8.90@149 in good air, off the stop. (1/4 mile)
$17000 usd turn key, or $13000 usd less engine.
Engine: 406sbc
Axle/Gears: 5.14
Re: 84 Camaro Drag Car **Turn key**
new price is $16000us race ready, or $10500 without engine and trans
clear title
cheap opportunity to own a clean, consistent race car with a small block and run in the 8's
I've owned this car for over 12 years
located less than 5hrs from the Maine/ NB boarder
clear title
