82-92 Camaro
Re: 82-92 Camaro
Ok so i went to look a a 1987, z28 with 129,000 needs a headliner and the interiors redone and will need 2 front tires soon, the car was gray and now is maroon and gold and it looks like someone did it on their garage dorejams were not painted and paint dont shaine. What you guys think a car like this is worth?
http://delaware.craigslist.org/cto/3704037325.html
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
Re: 82-92 Camaro
This sounds like a project. I would save and spend more.... 5 -6 k ? Almost all of these cars will need some work because of their age, but if you start with a nicer car it will respond to the dollars you put into it better. You can end up with the same money in a beater as a nice car and still have a beater when you dump a bunch of money in it.
Engine: LB9 TPI
Axle/Gears: 3.45
Re: 82-92 Camaro
Chico..... After I posted.... I looked on Craigs for 3K Z28's and there were a bunch in my area.
I'm not sure about were you live ? and rust isn't a real factor here.
I do think you could do better than the car you have listed. Alot better, even in the 3K range, I think a guy with patients could find a pretty nice Z.
A car listed in the 4k range might be had for your budget price.
The main problem I have with the car you listed is the re paint.
Is this car going to be your main driver ?
Re: 82-92 Camaro
Van that is the only problem I have with it 2 the paint, here in pa I'm guessing this cars are gold because they look to be expensive for what you ar getting you should look into PA Craigslist it is insane. And no it will not be a salt driver.
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
Nov 16, 2015 01:13 PM
