Canadian Region Take off to the Great White North.
Where to get alignment in Lower mainland area?
Old Sep 16, 2003 | 04:29 PM
CheezX's Avatar
I'm getting new tires and I need an alignment badly. Anyone know a good place?
Old Sep 16, 2003 | 09:53 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
And i need a place to get my SFCs installed, because it's still not done and I'm not happy with any of the places I've gone too yet.
And frame checked...
Old Sep 16, 2003 | 10:34 PM
CheezX's Avatar
I have a MIG welder and know how to install the SFCs, I made my own and put them on my car.
For frame checking isn't it just measuring certain points under the car and comparing against what the shop manual says? Was your car hit before?
Still looking for alignment shop...
Old Sep 16, 2003 | 11:25 PM
waltersb's Avatar
Maybe if you get a chance, I can take a closer look at what you've done....
I want to be involved in the install too so... you got a lift? or access to one?
Old Sep 17, 2003 | 01:47 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Where to get alignment in Lower mainland area?
Give John Chilton at Grandview Tire a call. Tell him Chickenman sent you. 12 th and Commercial in Vancouver. He's astraight shooter and used to Autocross. Really good alignment guy. Good overall mechanical shop as well.
604 872-8551
Old Sep 17, 2003 | 01:56 AM
CheezX's Avatar
I didn't use a lift, I did it in my really messy garage. I put jackstands under the front a-arms and rear axle so the frame would be loaded the same as if it was sitting on the ground.
Attached Thumbnails Where to get alignment in Lower mainland area?-sfcs-1.pg.jpg
Old Sep 17, 2003 | 02:01 AM
CheezX's Avatar
I wouldn't charge anything for labour as long as you do all the fun stuff (prepping the weld area, pulling interior, etc.) You'd only pay for the welding materials.
Attached Thumbnails Where to get alignment in Lower mainland area?-sfcs-2.jpg
Old Sep 17, 2003 | 02:03 AM
CheezX's Avatar
Re: Re: Where to get alignment in Lower mainland area?
604 872-8551
Thanks for the info Chickenman!! I used to autocross and now I'm looking at running the Silver State Classic. So his experience will definately help.
Old Sep 30, 2003 | 01:11 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I know this post is a little old, but don't get your alignment done at Midas. They keep telling me that they can't do it because this or that needs to be replaced. And they f*@^ed up my brakes.
J-money
Jan 4, 2019 09:45 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
machinist21
Sep 5, 2015 03:03 PM
mrdevontay
Sep 2, 2015 08:04 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
