FS: roller cam and lifters
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
For sale
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,000-5,000 RPM
Intake Duration at 050 inch Lift: 206
Exhaust Duration at 050 inch Lift: 212
Duration at 050 inch Lift: 206 int./212 exh.
Advertised Intake Duration: 258
Advertised Exhaust Duration: 264
Advertised Duration: 258 int./264 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.487 in.
Valve Lift with Factory Rocker Arm Ratio: 0.480 int./0.487 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Grind Number: CS XR258HR-10
Also comes with matching roller lifters.
$175
Pics available
$175
Pics available
dimented24x7
Sep 6, 2015 03:51 PM
