430 big block and HD TH400 trans for sale. Medicine hat. Alberta
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Like the title says these are for sale. They are out of a 1969 Buick wildcat. These motors were rated around 380hp and 475ft/lbs of torque from the factory. The car did run when I pulled the motor. It has approximately 85,000 miles on it.
The motor is complete but partially dissasembled and has been sitting for awhile so it has some surface rust. I had the heads pressure checked and they were ok. The motor will need a rebuild.
Asking $250 for the motor and $150 for the trans or $350 for both.
Pick up only in Medicine hat, Alberta.
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Re: 430 big block and HD TH400 trans for sale. Medicine hat. Alberta
Come on somebody must want to turn there car into a pretzel
