FS 85 IROC 20min from Calgary
Car: 88 firebird
Axle/Gears: 10 bolt, 4.56's
BC car, will need out of province, bodys in good shape, pass side fender has a small dent/rust starting on the bodyline of the wheel opening, 3.42 posi drum rear (not the original) black interior, t-tops, converted to carb, 350/700R4, will need vacuum lock up, shorty headers, weind dual plane intake, edlebrock carb, k/n extreme flow air cleaner, corvette aluminum valve covers, hei, , gear drive, crane 1.5 roller rockers, compression tested between 150-160psi, cyl # 1 at 80, compressions coming back into the intake, cams not wiped out, must be a valve problem, paint wearing on the front spoiler, gotta love lowered 3rd gens, crappy compustar alarm that ive started to disect, needs to be taken out, grant wheel/blue leather, drivers seat worn a little on the door side from use, good toyo rubber, iroc wheels are ok, missing one center cap, tinted, $3100, as you can see, theres a little bit of snow in the way, hopefully the weather shapes up so i can move the car.
Car: 88 firebird
Re: FS 85 IROC 20min from Calgary
the car is now sold, not quite sure how to get rid of the add now? Mods, any help?
mustangman65_79
08-11-2015 03:17 PM
