second amp
Old May 6, 2002 | 09:34 PM
pronger44's Avatar
second amp
ive got a second amp my deck has two sets of RCA's but only one remote wire. so what am i to do about the other remote wire?
Old May 6, 2002 | 10:03 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
easiest thing to do (if you're only running two amps) is to run the wire to one of the amps and then just run another from that amp to the other. wont hurt anything. if you use more than two things (i guess youcan get away with 3), a relay is a very good option so you dont burn anything out in your deck.
Old May 7, 2002 | 02:52 AM
HI92Z28's Avatar
Engine: stock 350 TPI
Transmission: rebuilt stock tranny, b&m shiftkit
Here how to do the relay if needed....I allways use a relay if i'm doing two amps or more.
85--ground
86--remote 12v in
87--12v fused 5amps
87a--not used
30--remote output
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
