JBL or Infinity
Old May 9, 2002 | 10:46 PM
NEEDforSPEED's Avatar
JBL or Infinity
what wood" give me the most SPL
for db drag's... etc
whats jbl's and Infinity's watts RMS??
whats the best?
whats there max watt's
JBL BP600.1
Output 4 Ohms: 300W x 1
Output 2 Ohms: 600W x 1
Signal-to-Noise (dBA): >100
Frequency Response (±3dB): 20Hz - 500Hz
Total Harmonic Distortion: 0.1%
Input Sensitivity: 250mV - 4V
Die-cast chassis uses the entire footprint for amplifier cooling
"Direct-Connect" allows choice of 4 - 8-gauge power and ground cable
High-frequency switching power supply is more efficient, drawing far less current from the vehicle's electrical system
Four high-level and low-level inputs facilitate constant bass, regardless of head unit fader position
Variable electronic crossover and bass-boost optimize subwoofer performance
OR??
Infinity Beta Digital 300
Bridgeable: Yes
4 Ohm Stereo: 300W x 2
2 Ohm Stereo: 500W x 2
4 Ohm Bridged: 1000
T.H.D. + Noise:
4 Ohms: <8%<100Hz<35%>100Hz
2 Ohms: <1%
4 Ohms Bridged: <1%
Frequency Response (+0 -3db): 20Hz-1kHz
Signal-to-Noise Ratio: >90db
Channel Separation (100Hz-20kHz): >50db
Damping Factor: >200
DC Offset: <20mV
Dynamic Bass Optimization (DBO): Yes
DC Coupled Input: No
Variable Input (250 mV-9v): Yes
Power Fuse (ATC): 2
Efficiency @ Full Power: 80%
Carrier Frequency: 500KHz
A Line Rejection Operating Voltage: 11-16vdc
Remote on Current: <1ma
Quiascant Current: <2A
Max Current: <40A
Protection (auto reset):
Spkr short Yes
Spkr to ground: Yes
thermal: Yes
over voltage 16vdc
under voltage 9vdc
Dimensions (H x W x D):15-5/32 x 2-5/32 x 8-1/2" 410 x 55 x 216mm
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
84 TA NV
Sep 6, 2015 08:02 PM
CloudIROCZ28
Aug 27, 2001 03:38 PM
BlackBird305
Apr 23, 2001 06:49 PM
BlackBird305
Aftermarket Product Review
Apr 1, 2001 09:22 PM
