Help fast (bridging my US amp)
Old May 16, 2002 | 09:08 PM
85maro's Avatar
Will someone please show me how to bridge my amp to my 2 10's! My amp says "Bridge R+ and L-" Below I have a picture of my amp and subs. Now can you just connect the lines. And yes my amp is bridgiable(sp?).
Thanks for your help,
Tim
Old May 16, 2002 | 10:46 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Just connect the R+ to the + on one sub and the L- to the - on the other sub and connect the remaining + and - from both subs to each other. This is assuming both of your subs are 4 ohms. Wiring it this way your amp will see a total impedance of 8 ohms. You can also wire the subs this way: R+ to the + on both subs and L- to the - on both subs. This will bring the impedance down to 2 ohms but, if the amp isn't rated to handle 2 ohm impedances, the amp can overheat. Wiring it up the first way is the safest way but, the amp won't produce as much power. The second way will produce a lot more power but can damage your amp if it is not designed to handle the load.
Old May 16, 2002 | 11:05 PM
85maro's Avatar
Thanks for the quick reply! Thank you. Oh and i done what you said to do the second time and my amp would play for like a second them the amp would shut off. And my amp says it is 2ohm stable?
Tim
Old May 17, 2002 | 09:43 AM
caleb's Avatar
Car: 89' Iroc
ya its 2 ohm stable when your not in bridged mode, when you bridge it to 2 ohm, the amp essentially sees a 1 ohm load, and thats why it goes into protection mode.
Old May 17, 2002 | 02:21 PM
85maro's Avatar
Oh i see now, thanks for pointing that out.
Tim
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
