Is this possible?
Old May 20, 2002 | 10:32 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
Is this possible?
I have a Sony CDXCA750 with Multi disc changer controls. I recently received a Sony 10 disc changer with the FM modulator from a friend of mine. Can I eliminate the FM modulator and connect the 10 disc directly to the back of my deck and use the multi disc changer controls? If so, what would I need to do to convert it?
Old May 21, 2002 | 09:53 AM
deadtrend1's Avatar
i aint too positive, but I am leaning toward the negatice on this. I think they are in two totally different worlds. Converting it might even be more trouble than its worth. Sorry dude.
~Tim
Old May 21, 2002 | 12:32 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I am under the impression that when you buy a cd changer you get one of two models. Either the one with cd receiver controls or the one with the fm mod. I could be wrong though(it has happened once or twice).
Brian
Old May 21, 2002 | 01:11 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Well, I answered my own question, I called a local sound shop and they said that if it was older than two years old, it is possible. I took a chance and pulled my deck and plugged in the audio cables and the remote cable, eliminating the FM module. It works perfectly . My CD changer controls are compatable as if they were meant to be together. All the functions work and the sound is better than if I was to use the FM module.All I need now is some subs and an amp, and I'll be all set.
