Choosing the right amp!?iż
Old Jun 12, 2002 | 12:06 PM
cbarry's Avatar
What would be a good amp to power these well. They are the Pioneer COMP DVC's. I am thinking a Rockford Punch 250 but I dunno. I dont have a very big budget either so try to keep it fairly cheap in price, not in quality. Thanx!
HERE ARE THE SPECS:
12" Foamed IMPP (Injection Molded Polypropylene) Rigilite Composite Cone Woofer
Dual-Layer Urethane Surround
Direct Bobbin Mounted VCCS (Voice Coil Cooling System)
Conex Damper with Damper Ring
Lead Wires Integrated into Damper for High Reliability and Improved Power Transfer
Projected Pole Yoke with Vented Pole
High-Energy Ferrite Magnet with Bumped Back Plate
Low-Q Design for use in Small Sealed Box (1.2 cubic foot recommended)
Dual Voice Coil (2x4ohm) Design for Increased System Flexibility
600 Watts Max Music Power
300 Watts Nominal Power Handling
Frequency Response: 18-2,000Hz
Sensitivity (Efficiency): 89dB (1W/1m)
2ohm or 8ohm Rated
Old Jun 12, 2002 | 12:12 PM
mudaholic's Avatar
how many subs are you running? you might look into the jbl amps, you can get 1200+ (rms) watts for 285, 600 for 205, 300 for 145.. check out ikesound.com, jbl's are nice cheap amps that pump out a lot of power, and they're class d, so a bit more efficient...
Old Jun 12, 2002 | 12:16 PM
cbarry's Avatar
OOPS
I am running 2 12"s
Old Jun 12, 2002 | 12:18 PM
mudaholic's Avatar
the 600.1 might match up well.. you can wire up your 2 subs to 1 ohm, which the jbl can take, and they'll each get 300 watts, or slightly higher.. the jbl amps are a little underrated.. not too bad for about 200 (i think they have free shipping right now too)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
raymondandretti
Sep 27, 2015 06:43 PM
