where am I supposed to put a disc changer?
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
I just got an older pioneer disc changer because it didnt work so I repaired it and it works great now but the only problem is where the heck is a good place to mount it. I cant use the rear cargo area due to my subs and amp back there I need to find a place to put it any suggestions would be great thanx in advance
do you use your rear seats at all?? You could shave some of the foam off the bottom of one of them, and possibly put in some different type of hinge or something so it flips up and mount the changer underneath (if it fits).
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
YEP that's where my SONY is the "glovebox"
Originally posted by mtccl
Put it in the rear fender storage box.
eightsixseven
Dec 16, 2024 01:50 PM
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
That's what I did.
