How much space do I need.......
Old Sep 15, 2002 | 07:54 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I want to know how much space I need between the magnet of the Sub and the bottom of the Box, like the pic attatched.
I have 6" for a mounting depth. I can get:
Type-R it is 5 15/16"
Kicker Comp VR it is 5"
RF HX2 it is 5 7/16"
Which would be the best with the right amount of wattage?
Thanks,
Brian
Old Sep 15, 2002 | 08:13 PM
CamaroDriver's Avatar
Most companies recommend 1". But it's not gonna really 'hurt' anything by having it closer.
About the only problem that may occur is since some subs have a vented pole, then you may be restricting the cooler air from easily getting to the vent, but you should be OK since any air that's moving is cooler air anyway.
Old Sep 15, 2002 | 08:16 PM
Belker's Avatar
For a ported box the port should be unobstructed the same number of inches as the port is in diameter .... so I assume the same would hold true for a sub with a vented pole. If the sub had a 1" vent in the pole then I'd keep at least 1" between the sub and the bottom of the box. If the sub was unvented then I guess you would need just enough room to keep it from touching (to avoid noise caused by vibration).
84LsxZ28
May 17, 2020 02:21 PM
C409
Dec 17, 2016 09:35 PM
Lbibb
May 5, 2016 12:00 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:02 PM
Metalizer
Sep 13, 2015 12:56 PM
