question about boxes in general
Old Sep 22, 2002 | 04:04 PM
White Ninja's Avatar
do you guys screw 3/4 MDF directly into the other piece? isn't Fiberboard bad for screwing through the side or is that plywood?
and what kinda of glue do you use to reinforce it?
Old Sep 22, 2002 | 04:09 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I would "pre-drill" if you're using screws...probably not a bad idea too use them. drill about half the diameter of the screw,so the threads have something to catch. for glue?...can't go wrong with "liquid nails" brand glue. you should go back over the inside with silicone or more glue to make sure it's air tight.
BTW-use sharp screws to prevent splitting, and make sure you drill straigt into the other pieces....check out some other unfinished boxes to get some design ides.
Old Sep 22, 2002 | 10:21 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I always drill pilot holes for the screws and countersink them. I use 1.5" wood screws and use tite bond or elmers wood glue (the yellow stuff) on all joints.
Old Sep 24, 2002 | 02:57 PM
harry's91rs's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
I would also pre-drill as everyone else has suggested. However make sure you use wood glue. It is the glue that is suppose to hold the box together. The screws just hold the box together while the glue dries, but i'm sure that the screws add some strength to the box so don't remove them when the glue dries. I use 1-1/4" drywall screws and Elmers wood glue.
Old Sep 25, 2002 | 09:33 AM
Ragnarok_Tyr's Avatar
I also drill pilot holes and countersink. And also, the screws are what are going to provide the majority of the structural integrity of the box.......the glue just aids that. Just make sure you take the time on this, I've seen some really horrible boxes, held together with just glue, some with nails, even a couple (from the local sound shops) that were held together by a couple of staples and their carpet.
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
