rattle
Old Oct 1, 2002 | 12:33 PM
dirtybird's Avatar
rattle
All i have i Cerwim-Vega 6x9' and they rattle my frigin panels, whats the best way to get ride to get ride of this *** awful noise. I cant even listen to my music w/ the slightest amount of bass. Its really annoying. Thanks for the help
Old Oct 1, 2002 | 01:05 PM
Ragnarok_Tyr's Avatar
There are lots of culprits that can be causing it, do a search, you'll find tons of posts about this. The two most common are the vent in the door jamb, and the frame the speaker mounts to in your c-pillar. Weatherstripping/silicone/old rags, whatever you have handy will solve those.
Old Oct 2, 2002 | 10:47 AM
bigdave8301's Avatar
Yeah I used to have the same exact problem and it annoyed the crap outta me; I tried tighting the panels down until I almost stripped the screws and it still did it. I just took some old bits of rags and kinda wedged them in between the panels and the car, and it fixed it.
Old Oct 6, 2002 | 02:18 AM
TealRS2000's Avatar
One suggestion, it's a little more pricey though, get Dynamat!!! Or just surrender to the gods of rattle because there's no way to stop it!
Old Oct 6, 2002 | 07:40 PM
CaysE's Avatar
You can buy some foam spray stuff that will cure your problems, but it's kinda messy. I think your best bet is to get speaker mounting foam, double sided foam tape, or anything similar and place it wherever you have metal meeting metal or plastic.
You can tighten the screws on those door jamb vents all the live long day, but it'll get you nowhere. The vents are flat and the door jamb is slightly concave.
Old Oct 7, 2002 | 07:12 PM
White Ninja's Avatar
what i did was i got 2 10" subs, and i never heard the rattle again
Old Oct 9, 2002 | 12:31 AM
spitz74's Avatar
The best way to find the source is just to crawl into the back seat, take the cover panels off, and listen to the speakers with the base up. The most common cause is the vent in the door jam. Take it off and cut the rubber slotted material off of the back of the plastic vent. This usually cures most of the rattle. The next most common source of rattle is the speaker vibrating against the metal surface it is mounted to. If you can't torque the screws down enough to cure the rattle, slide some form of dampening material between the speaker and the metal surface. The combination of these two steps should eliminate the problems around the speakers, themselves. However, you may have additional noise from the plastic third brake light assembly or other sources. That's why there's really no sure way to fix it without crawling around the back seat (maybe for hours). Best of luck!
jrdturbo
Mar 31, 2016 02:58 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
