what is the difference
Old Oct 22, 2002 | 05:39 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
RMS and peak
I am guessing means tat peak is how much you can put through it at one point in time but what is the RMS reading for ?
Old Oct 23, 2002 | 12:22 AM
bigdgky's Avatar
dont worry about peak that means what it puts out for a millisecond
rms is what the amp actually puts out constantly
Old Oct 23, 2002 | 08:17 AM
White Ninja's Avatar
yep...RMS is a subwoofers nominal power handling - what it can handle all the time and sound the best, peak is what it can take during a musical burst.
- Andy
Old Oct 23, 2002 | 12:00 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
RMS Power vs. Peak Power
The amount of continuous power, measured in watts, that an amplifier produces is called RMS power. The higher the RMS figure, the louder and cleaner your music sounds. When choosing an amplifier, the RMS rating is the power rating you should pay most attention to.
Also, keep in mind that some manufacturers calculate the RMS power ratings of their amplifiers at different input voltages. For example, an amplifier rated at 100 watts RMS at 12 volts can produce considerably more power than an amp rated at 100 watts RMS at the more typical 14.4 volts.
Stereo manufacturers often display peak power ratings on the face of their products. The peak power rating tells you the maximum wattage an amplifier can deliver as a brief burst during a musical peak, like a dramatic drum accent. The RMS figure is more significant.
BTW, I didn't write all that. I found it.
AJ
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
