Remote Turn-0n
Old Oct 26, 2002 | 03:26 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Remote Turn-0n
I just had to take my pioneer deh-p430 back to the place I got it to send it off the get repaired. I twill take ateast 2 weeks.
So I want to hook up my older cd player up.
It's a crappy boss 25x2 cd deck. So I am guessing I can only run my front speakers and not my 6x9's right?
Ok the problem. I cant seem to find a remote wire on my head unit To goto my amp that powers 2 12"s. What do I do? I will take a pic of the back of the cd player, etc.
Brb,
thanks
Old Oct 26, 2002 | 03:28 PM
b ut the deck
does have rca outputs....
Old Oct 26, 2002 | 03:48 PM
Ok, it has these wires.
green/back stripe - left speaker (-)
Green -left speakers (+)
Gray/black - right speaker (-)
Gray - right speaker (+)
Yellow - Memory back-up
Black - Ground
Red - Ignition Switch
Pink - ?????Remote??????
A set of RCA's out - Signal to amp
Old Oct 26, 2002 | 05:41 PM
Devasin's Avatar
My remote wire on all of my head units have always been blue. Why don't you just hook it up to the accessory wire or hook up a toggle switch for now. Hope you figure it out.
Old Oct 26, 2002 | 06:52 PM
Well I hooked it up to the pink wire... and it works lol.
The pink wire is supostu be the power antenna or sumtin'
will this hurt nething?
Old Oct 26, 2002 | 09:00 PM
Peg8687's Avatar
power antenna is the remote wire....
You turn the car on and have power antenna the antenna will go up (ie. giving the antenna power)
You turn your car on and instead of putting the antenna up, its turning the amp on
Old Oct 26, 2002 | 09:35 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
That is not usually the case.
The power ant. wire is for that purpose.
Then there is a remote turn-on wire, for it's purpose.
On some decks, when you swithc to CD, the ant. wire turns off because it is no longer needed. You done need an ant. to listen to a cd. Then, no more subs. That is why they will have a remote wire also. Whenever the deck is on, that wire is constant. No matter if the radio is on, or any aux inputs...
Old Oct 26, 2002 | 10:47 PM
CaysE's Avatar
I believe Kj is right, although I haven't seen any newer-model headunits where you weren't able to use the power-antenna wire as a turn-on without problems. I like the idea of wiring it directly to the battery with a switch, if you have no other options. It adds a nice sense of control over your system.
Old Oct 27, 2002 | 01:25 AM
Yeah I would wire it to a switch but It will be a waste cause I wont need it when I get my other Headunit back newayz.
I dont have a power antena anyways so this will do.
Old Nov 5, 2002 | 10:30 PM
otterball21's Avatar
Amp turnon
All what your amp remote needs is a 12 volt power source. So anything that has 12 volts cha ching.. would turn on your amp. Aftermarket radios have this blue wire and it powers up your power antenna or amp. in your case the pink wire has 12 volts .. and it gives it power when your ignition is on.. all is good.. just make sure it shuts off when you turn off the ignition.. other wise you come out with one dead battery one morning
Old Nov 6, 2002 | 01:01 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
Re: Amp turnon
thats what i was thinking. why would you wire a remote from the battery with a switch? that seems like alot of extra work and unnecessary.
i think on MOST aftermarket radios, you can use the remote ant for a remote amp turnon. they are usually interchangable. of course if you have both, its best to use them where they are specified.
Old Nov 7, 2002 | 04:01 PM
CaysE's Avatar
Re: Re: Amp turnon
Ah you people have no vision. It's just a nice addition, that's all.
Old Nov 7, 2002 | 04:02 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
Re: Re: Re: Amp turnon
close, i think we have no PATIENCE.
Old Nov 7, 2002 | 07:13 PM
White Ninja's Avatar
on my ex girlfriend's car, she has a power ant and then i put an amp in. The pioneer only has 1 12v lead, so i just put a splice. So the power antenna and the amp get 12V...less current, but still enough push for them to recognize and turn on.
- Andy
Old Nov 7, 2002 | 08:28 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
- Andy
i dont think you would lose any current there but i could be wrong. i had 2 amps and 2 small turnons coming off the same amp turn on and they all came on fine. now i just have the 2 amps.
Old Nov 7, 2002 | 09:25 PM
EjBaL's Avatar
if any of you are that concerned, you could just do what I did and put a toggle switch IN the remote wire, that way if the amps every get hot or anything you just flip the switch so they can cool off for a while.
Old Nov 8, 2002 | 12:16 AM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
you could also do this to turn off the bass. this could come in handy if bangin pretty loud and you pass by a cop. if he pulls you over, flip the switch and claim your subs dont work. you could turn it way up and there would still be no bass. just a thought, not trying to encourage law breaking:rockon: .
Old Nov 10, 2002 | 09:02 AM
camaro6spd's Avatar
my new alpine headunit has a power ant and remote turn on....the ant is up only during radio use, not CD use...there is a new unit that you would have problems with if you tryed to do it like that.
i dunno about you guys but this CaysE seems like a phony to me, alot of his posts state general knowledge but there is always something that he adds to cover himself when he is wrong, i think he is just a post *****....
Old Nov 10, 2002 | 11:00 AM
CaysE's Avatar
All I've ever done on here is try to help people out and offer my opinions like everyone else. If I was a post *****, I'd have 4000 posts, not 400. Keep it to yourself, kthx.
Dictionary entry:
post ***** (pst hôr) n. Mark Shields
hehe
Old Nov 10, 2002 | 02:22 PM
admrlam's Avatar
Its usually okay until you have three or more devices turning on from the same remote lead. Well, three or more is the number ive gotten from asking around. After that its usually wise to run a relay thats triggered from the remote wire, and turns on your accessories.
Old Nov 10, 2002 | 07:19 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That's what a remote lead is.
There's a relay inside that amp that is triggered by the .5 amps from the HU. There's no need to worry about it. I've seen people run 5 amps off the remote lead from the HU. There is soo little current going through the remote wire that it can ground out and not hurt anything. After all, when's the last time you saw a remote lead with a fuse in it?
AJ
Old Nov 10, 2002 | 09:33 PM
admrlam's Avatar
Well, thats just what ive been advised by some people i really trust in the matter.
I WAS running 4 amps, an EQ, and a crossover all off the same remote wire, and it worked allright for the time i had it hooked up.
But, since ive been advised against it, and wiring a relay takes all of an hour, theres no reason not to be safe than sorry.
Old Nov 10, 2002 | 09:54 PM
KicKeR's Avatar
You could opt to bridge the 6 x 9"s to the cd deck, it shouldn't hurt.
Old Nov 10, 2002 | 10:01 PM
camaro6spd's Avatar
^^^^^^^I ment that in a playful manner. sorry bout that.
Old Nov 11, 2002 | 12:41 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
like i said i had 4 devices and it never had a problem. im pretty sure you can have close to 10 and be just fine.
anyone want to loan their amps to me so i can try?
Old Nov 11, 2002 | 01:58 PM
admrlam's Avatar
And like i said (lol), i just relayed it to be safe based on the advice of much more experienced (than me) professionals.
Im not disagreeing with you that it will work, as i said i had 4 amps and 2 processors running off it. Thats 6 items right there.
BUT.... In the event that it CAN cause problems later, i figured better safe than sorry.
Old Nov 11, 2002 | 03:49 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
i must apoligize. i came off as kinda rude there. i didnt mean to imply that you were disagreeing w/ me. and your right, it is best to be safe.
im sorry and i hope we can still be friends . ok so we werent ever friends but thats not really the point. ya know what i mean.
1992Z28!
Nov 19, 2015 07:33 AM
tglennon11
Sep 23, 2015 05:30 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
anesthes
Aug 24, 2015 08:18 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
