can i use a BOSE deck or not?? (urgent)
Old Dec 2, 2002 | 03:47 PM
squirrelybird's Avatar
i have heard, on this board, no doubt, that to use a delco-BOSE deck, you have to use all the BOSE speakers too. ...something about weird watts or amps or volts...something like that. is that right?? anyone use the bose decks with an otherwise stock system?? thanks
Old Dec 2, 2002 | 11:33 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I haven't worked with them, but the Delco/Bose systems use essentially a head unit with low-level outputs and the speakers each have an amplifier either built onto them or located close to them.
It's just like having a deck with pre-outs and a little amp on each speaker, nothing too high-tech really.
Old Dec 6, 2002 | 11:52 AM
JuicedBird's Avatar
I've done about all you can imagine with Bose systems, using aftermarket amps, speakers, subs, CD plavers, head units. The answer to your question is no, you can't use a bose decks to power anything but Bose amps and speakers. You see, the Bose systems have an individual amp for each speaker and the speakers are 2 ohlms (aftermarket head units run a little hot with them). My advise is that if you're not well versed in the Bose systems and you want better sound, is gut the Bose and start from scratch. The Bose stuff isn't worth the trouble to keep. Don't get me wrong, you can mix and match Bose and non-Bose components all you want, and it may sound good at first, but mixed components don't last long (blown speakers, amps and head units). If anyone wants answers to Bose questions, feel free to email me. I hope that helps.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
