Amp help
Old Dec 13, 2002 | 05:36 PM
Matt G's Avatar
Amp help
I have a question about what kind of amp I am going to need. I have 6x9 MB quart DTC 169 and Infinity Kappa 4x6 for the front and 10 inch infinity kappa perfect sub. What kind of amp/amps should I get to power the speakers? The headunit is an Alpine CDA-7893. I also want to know how to connect the speakers in the car to the amp, do they connect directly to the amp? what do I do with the speaker wires from the headunit? Opinions and some wiring help would be greatly appreciated. thanks Matt
1987 White Camaro berlinetta
Old Dec 13, 2002 | 06:06 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
do you have RCA outputs on the back of that head unit?
if not make sure that the amp has speaker-level inputs.
the speakers will hook up to the amp..
Old Dec 13, 2002 | 06:33 PM
Matt G's Avatar
I forgot to add that. The headunit has 3 pairs of outputs.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
