Factory tuner
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Factory tuner
OK...I have read some posts about factory CD/tuners.I want to put a GM one back in my '91 Camaro and I was wondering what other year above 1991 will fill in my car.I am pretty sure the wiring harness is probably the same.Do they go up to the 2000 year made ones or stop at a certain year.?ANY help would be nice.Thanks guys.
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
as you guessed on the wiring, it is the same, however the mounting holes on radios '93 and up are different, so you can only use radios made BEFORE 1993.. or they won't line up right..
