gotta question...
Old Jan 10, 2003 | 08:07 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
gotta question...
if i buy my friend's factory cd player and disc changer. how hard will it be to install. his car is a 98' Z28. i know it will take a little custom wiring but it shouldnt be too bad should it?
Old Jan 10, 2003 | 09:35 PM
MoJoeVanilla's Avatar
the wiring should be fairly easy then again on the CD player, i've installed like 5, but i've never installed a changer before...just look stuff up on like install.com, or other online places and you could probably find how to do it
Old Jan 16, 2003 | 07:36 PM
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
the wiring is easy, just use Metra part #'s 71-1858 to plug into 98 deck and 70-1677-1 to plug into the car wiring harness, color match the wires and plug in. you will also need an antenna adapter as the 98 has a smaller "GM" style plug, use Metra part # gm20. now for the hard part... the mounting holes on the 98 radio will not line up with the mounting holes in your car, if possible, just use self-tapping screws to go through the plastic where the holes in the new deck sit. make sure that you got the 9 pin slave cd wire that plugs into the deck and changer... if you did, run the wirre to your mounting location and plug in... have fun
Galaxie500XL
Oct 1, 2015 01:05 PM
happyhapka
Aug 15, 2015 04:42 PM
KlayBuRn
Car Audio
Aug 30, 2001 12:52 AM
Lotsokids
Carburetors
May 28, 2001 08:42 PM
The ODB
Carburetors
Feb 1, 2001 03:29 PM
