The classic question... Edelbrock or Holley?
Old May 23, 2001 | 11:54 AM
Lotsokids's Avatar
I was told yesterday at a "carb shop" that the Edelbrock 600 is WAY more efficient and easier to work on... better gas mileage, too. O.K., the question... I'm about to take a long trip and need to know what kind of gas mileage you've experienced with either an Edelbrock or Holley 600.
Old May 23, 2001 | 01:19 PM
Jester's Avatar
holley.
Seriously tho..use the search function at the top of the page. This question has been asked about 3 dozen times.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 23, 2001 | 01:52 PM
Blucamaro's Avatar
I have a edelbrock 1406 600 cfm carb and so far it's been good to me as far as mpg,Don't hold your breath! Just Kidding long trips it does pretty good,Stop and Go<----Forget it!as with any car it sucks for stop and go driving....
http://community.webshots.com/user/blucamaro
Old May 23, 2001 | 06:38 PM
Cosmik Debris's Avatar
My opinion for what it is worth is this. Buy the carb that you can work with. I think all carbs have their good and bad features and with work they can all perform well. Buy what people around you (friends other racers etc) have because then there is a pool of knowledge available to you to get your tuning right. I bought a Holley not because I was necessarily conviced it was "the best" but because everybody around here has one and I knew that I would be able to get it setup properly.
Old May 23, 2001 | 08:28 PM
82camaro's Avatar
Car: 82 camaro SC
What he said, buy what you know--or what what your friends know. Holley for me.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 23, 2001 | 10:40 PM
SUPER-SPORT-CHEVY's Avatar
Like they said its probably better to get the edelcrap cause its easy to work on.
But as far as fuel economy/power Holley's are the best aftermarket carb. Ive used all of the cheap 250$ carbs holleys have more power and I avarage 5+ mpg more with a stock holley vrs a stock edelbrock, Or a well tuned edelbrock for that matter.
Long trip I assume 75 MPH driving? Thats dipping into the 4bbls on and edelbrock. While the seconadries on a holley are cloed untile you need them saving you lots of fuel.
SSC
Old May 24, 2001 | 04:56 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
For performance I would not think of using anything but HOLLEY.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
Old May 28, 2001 | 08:42 PM
camabird's Avatar
I have had nothing but trouble with holley's. It must just be my bad luck or something. I personally would go with a carter AFB carburetor. It is fairly similar to the edelbrock, but I get good gas mileage and performance out of mine. Mine is the carter AFB 625.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
3.8TransAM
Oct 1, 2015 07:47 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Royal_Z
Sep 30, 2015 08:45 PM
Night rider327
Sep 25, 2015 04:47 AM
