Sub pops when deck powers up...
Old Jan 13, 2003 | 08:04 PM
Matt86Z's Avatar
Every time my deck powers up or powers off (when starting or shutting off the car) the sub makes a loud "bump". I have a late model JVC deck and a 300 watt internally powered 10" tube. The sub has a separate fused line off the battery.
Old Jan 13, 2003 | 10:03 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That happens sometimes, usually with a cheap amp. If the amp doesn't mute the input when it powers up, it can cause the power spike sent from the deck to get to the subs. Unless it's excessively loud, it really isn't causing any damage.
Old Jan 19, 2003 | 02:46 AM
92 z28's Avatar
your problem is most likely from a bad ground. make sure your ground from the amp to the chasy is getting a good connection. try to make sure its not just on top of paint, it should be bare metal.
Old Jan 20, 2003 | 11:35 AM
Jim85IROC's Avatar
I don't think a ground will effect turn-on thump. Turn-on thump is caused by voltage spikes from the source unit, which don't really have anything to do with the ground.
Old Jan 20, 2003 | 02:23 PM
THEISENATOR's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
I had a rockford 500 that did that...i returned it and they said it was due to overheating
Old Jan 20, 2003 | 02:57 PM
JPrevost's Avatar
Car: 91 Red Sled
cheap amps do this, there are products that'll fix it
http://www.davidnavone.com/amp.html
Old Jan 21, 2003 | 10:08 AM
jawzforlife1's Avatar
I had the problem with my rockford amp and subs, It was just a bad ground, fixed in in about 1 minute.
gixxer92
Sep 1, 2015 04:32 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
