2 12's vs 1 10
Old Jan 27, 2003 | 09:35 PM
5.0L1992RS's Avatar
2 12's vs 1 10
Ok, here is my current setup. 2 audiobahn 12's they are 400 watt RMS each. I have a audiobahn amp, 560 watts RMS.
I really want to get rid of the box in my trunk so i can actually have some space. I saw REZN8R's "stealth" box, and that really sparked my interest. So i am looking for a 10" sub. I am thinking about the Audiobahn ALUM10Q. it has 800 watts RMS and dual 6 ohm voice coils.
My question is, how loud is the single 10" going to be compaired to my 2 12's?
Any comments are welcome.
-Kevin
Old Jan 28, 2003 | 12:25 PM
5.0L1992RS's Avatar
someone has to have an opion on this.
Old Jan 28, 2003 | 12:31 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
roughly half of what u hear now. there is less air being pushed so...it will still sound better than without em but not as good as 2 12s
Old Jan 28, 2003 | 02:16 PM
mudaholic's Avatar
depends on the driver you get, and how much power you want to push with it. im particularly fond of the adire brahma sub, its relatively cheap ($330), but can mechanically handle 1600 watts rms.. i actually got a note with my sub that said powering it with more than about 800 watts will cause your ears to bleed.. so i bought a 1500 watt amp the point is, a good 10 can sound incredibly loud, and the box is less than one cubic foot... and i guarentee you that my setup blows away most people with 2 12s
Old Jan 28, 2003 | 02:24 PM
5.0L1992RS's Avatar
I'm not real good at car audio, what exactly do you mean by driver? do you mean the amp? I would be using a audiobahn A2801. It has 560 watts RMS x 1 at 4 ohms.
I really don't need anything loud, just enough for cruising.
Thanks for the replies
Old Jan 28, 2003 | 02:30 PM
mudaholic's Avatar
driver = sub. is your amp stable to 2 ohms? if so, what kind of power output does it provide at 2 ohms?
Old Jan 28, 2003 | 02:36 PM
5.0L1992RS's Avatar
umm, i'm not sure if it is stable single channel. the specs show 280 x 2 @ 2 ohms. it also has 200 x 2 @ 4 ohms. so i don't know if it is stable.
Old Jan 28, 2003 | 04:43 PM
mudaholic's Avatar
what model amp is it? is it bridgeable into a single channel?
Old Jan 28, 2003 | 04:45 PM
5.0L1992RS's Avatar
it is bridgeable, it is model number A2801X.
Old Jan 28, 2003 | 06:14 PM
mudaholic's Avatar
the thing about the sub you mentioned is that its got funky voice coils. you'd have to either wire it at 3 ohms (which is below what your amp is published to handle) or 12 ohms, which would provide terrible output. what kind of budget are you on?
Old Jan 28, 2003 | 06:58 PM
5.0L1992RS's Avatar
I would like to stay under 450 for the box and sub. So the box is 200, so i would like to stay under 250 for the sub. This is flexable though, so let me know what subs you think i should get. Thanks for all of you help.
Old Jan 28, 2003 | 08:42 PM
mudaholic's Avatar
if you arent looking to get too loud, you can pick up an alpine type-r, its a nice sub with good power handling. also look at infinity perfects or jl subs. if you want to spend a tad bit more, you could go with an adire brahma ($330)
Old Jan 28, 2003 | 09:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Mudaholic, have you measured the SPL of your setup with the 1 brahma 10? I've been planning on replacing my 2 12" oz subs with a single Brahma 12", but the thought of using a 10" has crossed my mind too.
Old Jan 28, 2003 | 09:12 PM
5.0L1992RS's Avatar
mudaholic, thanks for all of the help. I think i am going to go with the audiobahn aw1000Q. it is 600 watts RMS x1 @ 4 ohms, so my amp, being 560 RMS x1 @ 4 ohms should power that nicely.
Old Jan 28, 2003 | 10:35 PM
efbaudy's Avatar
stay away from crappy 6 ohm set up try to get to 2 ohm...as if that wasnt already common sense
Old Jan 28, 2003 | 10:57 PM
mudaholic's Avatar
5.0- keep in mind that the 1000q is a dvc driver, so you are gonna end up with a 2 ohm load or an 8 ohm load.. neither one compliments your amp very well. if i were you i would look for a 4-ohm SVC sub or a 2-ohm DVC.. those will allow you to maximize the output of your amp
efbaudy- his amp doesnt handle a 2 ohm load bridged...
jim- ive never had it metered, its a sexy setup tho.. ive never actually heard a brahma 12, would be interesting to compare it to my 10 tho... ive been incredibly happy with the brahma, i definitely dont think you can find a better sub for the price
