power cable
Old Feb 9, 2003 | 10:05 PM
ssnow2020's Avatar
power cable
I was wondering if it was ok to run my cable to the back of my car going under it, I was going to zip tie to my fuel lines going back, is this make sense or would that just be dumb?
Old Feb 10, 2003 | 01:17 AM
onebadwagon's Avatar
it would work, but if you did happen to chafe it and it grounded, that would suck.
adam
Old Feb 10, 2003 | 09:54 AM
mcss383's Avatar
You can run your wire under the car, just make sure you protect it. At the bare minuimun I would put some expandable sleeving from www.techflex.com and then cover that in some plastic loom (fire retardant or heat reflective). Go to www.mcmaster.com to get the loom (go here).
Then you can attach it anywhere out of harms way under the car.
The best method for running power wire under the car is to run it through some metal conduit, but that can be a lot more tedious than just tie wrapping it to the frame.
Old Feb 10, 2003 | 11:14 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
why would you do it outside of the car? its gonna be as much or more work to get it under there out of the way of the exhaust or anything moving. its not that difficult to run it through the interior. couple plastic pieces and you're done
Old Feb 10, 2003 | 11:16 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
if you do go under, keep it away from the heat. heat creates an impedence rise lowering the amperage your amps sees.
Caspar
Jun 19, 2016 11:19 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
