Am I going to blow up my deck doing this?
Old Mar 14, 2003 | 06:51 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Hey guys,
I have some crappy subs that came with the car on a board. I've never listened to them and will throw them away, but I would like to hear them first.
I was thinking about just running the subs strait from one of the rca preouts by just touching the wire from the sub and sticking it into the rca female hole.
The subs are tiny, probably 8" MTX road thunders that have paper cones and are at least 3 years old, but are probably older than that.
All I want to do is hear the subs, I am not even going to mount them.
Any suggestions or comments are welcomed,
Jesse
Old Mar 14, 2003 | 07:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
RCAs carry signal voltage to tell an amp what to do......they can not power a sub, and it isn't a good idea to ever EVER EVER hook up your subs to a radio deck.
Old Mar 16, 2003 | 04:22 PM
Mirthman's Avatar
Car: 1988 GTA Trans Am
Engine: pos 305
Transmission: 700r-4
well if you want to get rid of those subs that bad, plug them into the wall outlet. i know a guy that did that with his old sub, but put it so its cone side down on the ground and magnet in the air, do this in a well vented area plug it and enjoy the effect.
Old Mar 16, 2003 | 04:35 PM
oldblueZ's Avatar
Car: 85 Z28
Maybe I'll plug them into a wall later, but the whole point is to hear them, then blow them up....so I need some other ideas on how to listen to them...
thanks,
Jesse
Old Mar 17, 2003 | 02:20 PM
White Ninja's Avatar
do you have a home stereo system that uses + and - wiring? you could hook it up to a home audio reciever.... that's what i've done in the past.
- Andy
Old Mar 18, 2003 | 06:18 PM
Snow90Camaro's Avatar
back when i drove an 86 camry i ran all 4 channels to a sub heh it worked for awhile but i had some hard bass hit one time and blew the fuse on my radio so i unhooked it all......i'm pretty sure your radio will blow the fuse before it damages anything
Old Mar 19, 2003 | 10:26 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Probably.
Not the way to think.
Old Mar 19, 2003 | 01:10 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
RCA outputs can barely power a pair of headphones.
Old Mar 19, 2003 | 03:26 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Your missing the biggest problem with this. The pre-amp outputs (RCA outputs) are high impedance outputs not low impedance outputs. Your speakers, subs or headphones, are a low impedance load. That’s what “could” damage the deck.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
skinny z
Oct 5, 2015 06:23 PM
Fanatic1074
Oct 2, 2015 03:47 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
