Too Much Static From Subs
Old Mar 14, 2003 | 07:52 PM
nhamze's Avatar
I had recently replaced my amp with a better one, it worked fine for awhile but now whenever I am on the radio or if the volume is real low there is a lot of static, the subs are just bouncing up and down with no rhyme or reason. What could be causing this? I checked, the ground, power, sub cables, and preouts and they all look to be snugy secured. Any help would be appreciated.
Old Mar 15, 2003 | 10:08 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
If your amp power leads run close to your RCA leads you will get some interference. Try seperating all your leads.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
