amp/wire question
Old Apr 11, 2003 | 05:26 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
amp/wire question
I have an old amp and it has RCA inputs (labeled channel 1, channel 2, etc) and no other connectors (like for the speaker wire and ground, power, etc) however it has a harness input but the problem is I don't have the harness. Does anyone know how to hook up an amp like this w/o a harness cause its really not worth the trouble of buying a new one cause like I said, its old.
Also, I have batteries in the hatch and does running the speaker wire beside my battery cable (positive of course) would effect the transfer of signals through the speaker wire? If so I will run the wire to the other side and then behind the seat.
Cheers
Old Apr 11, 2003 | 07:20 PM
Tyler-88's Avatar
sounds like youd be better off to buy a new amp. by time you rig up a new harness to get things working, the time saved could buy you a newer amp.
keep all non 12+ wires away from 12+ wires. i ran my rca's down one side of the car, and my battery wire down the other side of the car. people recomend that you keep them 18" apart. down the other side of the car is good enough for me
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
