few amp qustions
Old May 4, 2003 | 08:43 PM
87camaro kid's Avatar
Car: 1987 Z28
few amp qustions
1) ok first how do u wire up a second amp...........like how do i put a second power wire.............do i run a second one from the battery or do could i splice a second one into the existing power wire near the back of the car.
2) i did try to wire a second amp...........i spliced in the power wire from the already in use power wire right in the back so i didnt have to do any wiring or anything and i ran the rca cables on the other side of the car along with the front speaker wires. i put the ground wire to the same spot where the other amp for the subs is. ok so everything was hooked up correct and when i turned it on and no musik was playing i hurd a fuzzy noise it was not that loud though but when i like changed a song it would make weird beep noises. when the car was on i could hear my altinator threw the speakers and when i poped the trunk i could here that motor threw the speakers to. what could be the problem?
Old May 4, 2003 | 08:47 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
Well to wire up two amps you would need a distribution block. That will take in one power line from the battery and split it into two power wires. The reason you're hearing the alternator thru your speakers is because the power and RCA cables are run too close together, run them on oppossite sides of the car and that should take care of your problem.
Old May 4, 2003 | 08:58 PM
Car: 1987 Z28
yeah thats how it is sry i guess i forgot to say that
Old May 5, 2003 | 02:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: few amp qustions
Yipe! Make sure the original wire from the first amp to the battery is thick enough so it doesn't overheat and catch fire. You don't want to be running two large amps off a thin-gauge wire; or your car will literally go up in smoke. If you total up all of the fuses on the amplifiers, what's the total? And what gauge is the original wire?
Old May 5, 2003 | 05:39 PM
Car: 1987 Z28
the 800 watt amp has a 20 fuse and the 400 has a 10 and i belve the wire is an 8 gauge
right now the 400 is disconnected cause it didnt sound to good with all those bleeps and engine noise comin out of the speakers lol
o yeah and one other thing after i did that and disconected the 400 watt i left the wire spliced in because i sodered it together but now everytime my volume goes up and the bass getes harder my amp fuse for the subs the 800 watt amp blows and it doesnt work what could be the problem.......i was thinking mabey because right where the wire connects to the amp is geting a little messy because its at a right angle and i didnt crimp it to good so i think the wires r breaking a little
Old May 6, 2003 | 10:39 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Okay... glad I asked you for the fuse ratings. Those amps aren't 400 and 800 watts... probably more like 100 watts and 200 watts. Anyway,your 8 gauge wire should be fine for 30 amps. Make sure you also have a fuse near the front of the car on the 8 gauge wire, 18 inches or closer to the battery.
Old May 6, 2003 | 02:24 PM
Car: 1987 Z28
well yeah its 800 watt max and 400 watt max the rms is 250 rms and im not sure about the other and yeah i have a fuse near the battery
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
