Aftermarket Windsheld attenas
Old May 18, 2003 | 01:32 AM
maverick544's Avatar
Its beena while since I've seen this talked about but I remeber a while back TomP I think talking about getting a attenna that was a strip that went along the top of the winsheld. Where can I find this or does this even exist. I could have been dreaming or something lol who knows. I went to radio shack and the guy didn't know what I was talking about, lol like they ever do.
My power attenas having issues again and I'm thinking bout pulling it out if I cant get it going. I wanna also get a bearcat scanner to put in my car cause I installed a 95 Camaro console and looks great, but has a about 1"5 to 2'' gap between the frin of the console and the radio pod and that scanner would look very good filling the empty area . I But I dont want to have a ugly big scanner attena to ruin the sleak look of my car.
Old May 19, 2003 | 01:05 PM
Tomp I know your somewhere around here bud! Holla at me peeps!
Old May 20, 2003 | 12:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't remember ever asking about a window-mount antenna... must've been someone else? JC Whitney probably sells one; don't know how good it works...
Old May 20, 2003 | 08:51 PM
1989TransAm's Avatar
For my scanner I just have glass mount antenna on the rear window up top, doesn't look that bad, gets great local reception...just my 2 cents. Or what you could do is just get a fixed antenna, and they cell a kit for 20 bux where you can wire your scanner to the antenna so you can use it for both the radio and the scanner, i found that out AFTER i put my glass mount on
Old May 20, 2003 | 10:49 PM
Where could I buy that kit or that back window mount attenna at?
Old May 21, 2003 | 12:09 PM
the kit i found is here http://www.valcoelectronics.com/scanner/scanner.htm for $12...there could be cheaper ones, so look around
the glassmount antenna can be found anywhere... radioshack sells them as well...if you do put the glassmount on, don't have it going over the defroster lines, as that could cause static when the defroster is on, try to fit it inbetween the defroster line...also if you antenna doesn't have a double sided sticker on it your best bet would be to stop by a local body shop and ask for 3/4" molding double sided tape, i had mine give it to me for free...it works the best, also wouldn't hurt to put some silicone around it.
Old May 21, 2003 | 12:11 PM
almost forgot, your having issues with your power antenna, so make sure you get that fixed, or replaced with a fixed antenna, so you get best reception through that if you're gonna use the kit.
Old Jun 3, 2003 | 10:00 PM
tregnab's Avatar
I used a windshield mounted ant. on my '88 and I got it from Radio Shack. The wire is super thin, you have to be careful installing it. Once I got it in, the reception was great.
It looks crappy, basically a wire with scotch tape stuck to it with some resistors on the end - but it did the job.
Old Jun 7, 2003 | 09:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My MECP friend told me about a "patch antenna". It's a little square that goes in the upper corner of your windshield, recieves AM & FM, and is amplified. I gotta do a search on them; I'd love to shave my antenna off.
Old Jun 7, 2003 | 11:26 PM
Badazz85TA's Avatar
Car: 1985 Trans Am
Transmission: 700R4 Automatic
Ey tregnab, how much is da antenna at Radio Shack. I would also like to do the same as maverick544 since my power ant is dead.
Old Jun 15, 2003 | 03:09 AM
JHens's Avatar
dakota digital guages (dakotadigital.com) sells an antenna that is a little black box that you could throw somewhere in your hatch, it's amplified, but it's a bit pricey I think, over $100 if I'm not mistaken.
Old Jun 16, 2003 | 07:35 AM
Mirthman's Avatar
Car: 1988 GTA Trans Am
Engine: pos 305
Transmission: 700r-4
i got out my old super chevy magazine today cause i remember seeing install a stereo in a monte carlo and this is what they used for an antenna http://www.customautosound.com/prodList.php?FamID=13
Old Jun 25, 2003 | 12:50 PM
tregnab's Avatar
It was less than $15 when I bought it. The guy at Radio Shack didn't even know he had it, so all the stores may not carry them. Also, when I said it looked crappy, I meant when it's in the package. Once it's installed you can't see it.
Old Jun 25, 2003 | 10:54 PM
Makaveli's Avatar
i remember in that super chevy mag when they did the silver blue camaro project, they used a hidden antenna of some sort that was stored in the car, nothign to do with the outside. maybe im wrong, its what i rememberd, thought it was very cool.
Old Jun 27, 2003 | 07:41 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Last time I looked radio shack had the wire type window antena. But its been a while.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
