What's the total CF available in the hatch?
Old May 24, 2003 | 05:56 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Curious if anyone has built a single woofer box for the rear hatch well, and how many CF can you get out of it?
I'm hoping to get around 1.5 CF with a depth of at least 16 inches down, so I can run a port, and tune my woofer to 35 HZ.
Anyone have an idea on the available CF? Looks like a measurement hell, so I was curious if anyone already has the information.
Thanks!
Old May 24, 2003 | 06:33 PM
9177's Avatar
You should beable to get 1.5 cu ft out of the well alone. I'm getting 1.6 and the blox is only 14" high
Old May 24, 2003 | 08:43 PM
Christos's Avatar
Sweet, thanks for the info.
Do you happen to have your box's specs anywhere handy?
Old May 25, 2003 | 06:48 AM
9177's Avatar
just a wedge 26" inches wide 14"tall d1 11" d2 9"
Old May 27, 2003 | 04:59 PM
Ragnarok_Tyr's Avatar
My box is a little over a cube and a half, doesn't even come all the way up to the bottom of the hatch pull-down motor, and has about 6"clearance to one side. Wedge-shaped box,
W1- 14.75", W2- 10.75, H- 11.75", L-22.75" I had to cut part of the mount the hatch motor is bolted to to get it to fit (the guy who built my box makes an awesome-sounding enclosure, but is a total retard when it comes to math.)
Old May 31, 2003 | 04:34 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
That sounds like kind of a paradox since there's a ton of math involved in getting the airspace right.
Anyway... You can definently get 1 cu. ft. in the well area. My enclosure comes up to the top of the gas tank (behind the rear seats) and I have around 1.5 cu. ft. all together. If you use fiberglass you can get the same amount of airspace with less height since the well area is curved in several places making it impossible to get an MDF box to take up every cubic inch.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
jaridjohn
Oct 5, 2015 07:01 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
