do i need subsonic filter
Old May 30, 2003 | 06:16 PM
hawkeyeZ28's Avatar
would i need one for the JBL 600.1 amp if i am going to use a sealed box?
Old May 30, 2003 | 09:03 PM
9177's Avatar
No SS filters are needing in some ported applications.
Old May 31, 2003 | 02:53 AM
Ragnarok_Tyr's Avatar
Subsonic filters are intended to keep the amp from wasting power by amplifying frequencies that are below the range of human hearing (below 20Hz, usually). Subsonic fequencies can also muddle other, audible frequencies that the woofer is making. Unless you are trying for the purest sound possible (and keep in mind, the difference is almost too small to hear), don't cosider a subsonic filter a 'must-have' feature in your new amp. Most dedicated bass amps nowadays include this feature anyhow, so, if you spend any kind of money on a new sub amp, you'll probably end up with an amp which has one.
Old May 31, 2003 | 03:37 AM
onebadwagon's Avatar
also, in a ported box, if you play frequencies way below the tuning of the woofer/box, you can shred your sub(s).
so the subsonic filter protects your subs in some ported apps.
adam
FormulasOnly
Oct 2, 2015 05:52 PM
