Where does the 12V source come from
Old Jul 6, 2003 | 01:51 PM
Z89IROC's Avatar
I am needing to know how the 12 v battery source works I think that I might have blown some kind of wire or fuse I heard a pop under the hood at least that is where sounded like it came from when connecting a new cd player I forgot to disconnect the battery.
Old Jul 7, 2003 | 02:44 AM
jeff1367's Avatar
Did you check the fuses?
Old Jul 7, 2003 | 09:02 AM
MdFormula350's Avatar
i would check ur fuse panel, most likely blew a fuse when you exceeded current flow by grounding out the 12 volt wire.
should not be to big of a problem just through in a new one.
i blew a fuse when i dropped a screw driver in the cig. lighter. a few days ago.
Old Jul 7, 2003 | 11:21 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
try droppping a penny in the cig lighter, its just the right size to lay flat on the bottom, ERRRRR, anyways, check the fuses, I don't know af any inline fuses in the radio system. Unless there has been an aftermarket system before hand the radio may have a fuse in it also, as well as a inline fuse.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
KCG
Jun 24, 2020 04:33 AM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 20, 2016 01:01 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
