Subs go where?
Old Aug 20, 2003 | 02:37 AM
Abaddon_fallen1's Avatar
Car: city bus
Engine: turbo diesel
Transmission: auto
Axle/Gears: be damned if I know, it's not mine
Subs go where?
Any body have any ideas where I can put two 10" subs without removing the rear seats or putting a box in the trunk (I'd rather have somewhat of a trunk, no matter how small, to no trunk at all.) The amps will go right on the rear deck behind the seats.
I'm open to all ideas and suggestions.
Old Aug 20, 2003 | 07:03 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Well, since you've completely eliminated the only open space as a possibility, that leaves 6x9 locations or the spare tire area & corresponding area on the other side. Neither will be cheap or easy.
Old Aug 20, 2003 | 09:45 AM
nolanr0413's Avatar
Car: Trans am
they make a box that goes on the rear shelf directly behind the passengers head. subenclosures sells them i think . one guy also put a 10 sub where the 6x9 went, he had to cut some plastic but you couldnt tell anyone was ever in there once the cover was on.
Old Aug 20, 2003 | 11:23 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
See the add on top of the page... subenclosures.com?
Go there and look at his Stealth box
Old Aug 20, 2003 | 01:48 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I used to offer a box for the shelf, but I stopped making MDF boxes. It's really just a simple rectangular box that measures about 42x13x7 O.D. There's only enough room there for about 1.5 cu.ft. airspace if you still want to see out the rear window. Just make sure and use some metal brackets to attach the box to the shelf so it doesn't move around (and don't drill into the gas tank!).
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
