Can 4 channel amp have different loads per channel?
Old Sep 8, 2003 | 03:08 PM
lavamadness's Avatar
Car: 1989 Formula 350
Engine: 5.7L (L98)
I'm toying with the idea of getting a new amp. I'd like to run a set of component speakers up front with it and my two subs in the back. (I've heard that if you do this right, you don't really need rear speakers.)
First of all... is this a good way to build a system? If not, then I'll figure something else out. :P
But if I'm on the right track, my question is, if I got a 4 channel amp, could I run 4 ohm loads on the first two channels (the components) and 2 ohm loads on the second two channels (the DVC subs I have)? The amp I was thinking of is either the Kicker KX600.4 or the KX800.4
Old Sep 8, 2003 | 03:10 PM
Engine: 5.7L (L98)
The reason I'm not looking at a 3 channel amp is because I have 2 dual voice coil subs, and you can't wire them to 1 channel with a 2 ohm load. (Wish I had looked into THAT a bit further... but live and learn I guess.)
Old Sep 8, 2003 | 03:27 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
You’ll be fine as long as you use the channels in"pairs" like you said you would. A 4-channel amp is just two 2-channel amps with a bigger power supply in one box. Just remember to use the channels in “pairs”. You wouldn't what different loads on different channels in the same “pair”.
Old Sep 8, 2003 | 04:46 PM
Engine: 5.7L (L98)
Thanks. That's what I thought, but wasn't too sure.
Old Sep 17, 2003 | 01:24 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
u may be able to wire 2 dvc subs to 2 ohms on a single channel. what ohm is it per coil?
Old Sep 17, 2003 | 01:25 PM
Engine: 5.7L (L98)
Each voice coil is 4ohms.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
