Trying to get 2 ohms...
Old Oct 13, 2003 | 02:56 AM
Faded's Avatar
Car: '91 Firebird
Ok, here's the setup: two JL 12W3 D4's and a JBL 1200.1.
Ideally I'd like to have this system running both speakers at 2 ohms, ie 600~ watts to each sub.
Hooking these subs up mono in series results in a 4 ohm load, and hooked up mono in parallel results in a 1 ohm load. Just having one sub hooked up in parallel results in a 2 ohm load. so....
If I were too hook up each speaker in parallel and then run it stereo, should I be able to run each speaker at 2 ohms with this amp, or does it not work like that? Sorry if this is a newbie question.
Old Oct 13, 2003 | 08:31 AM
Polecat's Avatar
just run the JBL 12001 at 1 ohm...does the same power into 1 ohm as it does 2 ohm.
Old Oct 13, 2003 | 01:35 PM
Faded's Avatar
Car: '91 Firebird
It won't make it get too hot?
Old Oct 13, 2003 | 02:18 PM
Polecat's Avatar
nope...
Old Oct 13, 2003 | 06:43 PM
Faded's Avatar
Car: '91 Firebird
Sweet, thanks.
Old Oct 14, 2003 | 11:11 AM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
It won't do 1 ohm, even though it says it will (at least mine wouldn't)
Psycho_91Camaro
Nov 22, 2018 02:46 PM
ChevyRS-305
Oct 23, 2011 03:54 PM
bigal's1991
Car Audio
Aug 15, 2008 04:17 PM
ScrapMaker
Car Audio
Apr 22, 2005 12:27 AM
Xenodrgn
Nov 4, 2001 01:28 PM
