Wires, wires, wires...
Old Nov 26, 2003 | 07:58 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Hey everyone. I have an 87 TA. Im using a Pioneer DEH-P930 head unit. I have such a hard time making all the wires fit into the radio pod. Ive tried everything. I had a flush mount install kit in, but I recently put one in that makes it stick out about 1/2 inch. Which looks like ***. Ide like it to be flush or even better recessed. So my question...Does anyone have any ideas/tricks on getting all of the wires to squeeze in back there? Ive arleady trimmed some of the pod away in the back to make room for the radio itself. I have a 4th gen console, so some of the wires can come under the pod and go into the front of the console. But all ideas would be appreciated. I know its a simple question...probably a duh question but Im tired of getting frustrated over it. Thanks
Justin
Old Nov 28, 2003 | 09:54 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
Well you could drummel out the air ducts in there.
At the very least, you should be able to get by with removing the little square part that sticks out. It has the little hole that is there to stabilize the stock deck.
I found when I removed just that little square shaped part that sticks out I could fit my deck in with a flush mount.
Keep in mind there will be still alot of wire packing to do, but it is possible.
I hope this helps.
Old Nov 28, 2003 | 09:42 PM
87GTA Runner's Avatar
Car: 87 GTA
Like demicon said, you definitely have to cut out that square part with the hole in it. That should give you enough room. It will be a tight fit, but it does all go in. I have 3 sets of RCAs along with all the normal wiring and remote wires and they all fit.
Old Nov 29, 2003 | 01:31 AM
CaysE's Avatar
Two words: wire splicing! If wires are a problem, shorten the wires. Better still, bypass any connectors you're using and just hardwire everything together. It saves a lot of room.
Old Nov 30, 2003 | 09:23 PM
Car: 86 Trans AM
I definetly cut out the bracket piece. I think most of my problem lies in the fact that I am using an a wiring kit. Its big and bulky. Ide like to hardwire it all in, but I am always taking out the radio, and I dont feel like having to unsplice then re-splice everything. Maybe I can convert to a different plug. I also have 3 sets of pre outs, and a whole ton of extra wires coming out of the back of the head unit. Special feature wires etcs. I use most of them so cutting them off wont work. I kinda figured I would just have to mess with it, I just wanted to see if anyone had any creative tricks to making it easy. Any more ideas let me know...and thanks for the ones you gave.
Justin
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
