rear sub box sound
Old Jan 29, 2004 | 03:04 PM
SCcamaro88's Avatar
Car: 88 camaro t-tops
Engine: 2.8-3.4 swap
Transmission: auto 700r4
rear sub box sound
ok, im in the process of building a rear sound system, i dont know if i should go through the trouble and build a custom box in the compartment, or just buid a peice of wood to fit in that compartment, wich will sound beter?? or what will hit harder? ......Greg
Old Jan 29, 2004 | 05:16 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Build one for the WHOLE well......The only way that building just a cover piece is if you fiberglass the well. Check mine out....149.00 total (with shipping)
Old Jan 29, 2004 | 07:28 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Plate sub setups are usually horrible... unless you have free air subs.
3/4" MDF is the easiest to do. Make sure you seal all the seams up good and use the whole hatch area.
FIberglassing is the best, but is sorta complicated to do without some practice first.
Check out these pages for some fiberglassing step-by-steps if you got that route:
http://web.njit.edu/~cas1383/glassing2/
http://web.njit.edu/%7Ecas1383/glassing/
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
