Mounting Amps Upside Down
Old Feb 1, 2004 | 02:03 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Can amps be mounted upside down? or would this cause a heat problem..
Old Feb 1, 2004 | 03:46 PM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
As long as the amp can still get air I dont see a problem
Old Feb 1, 2004 | 04:32 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
the heat sinks on most amps are designed to decipate heat while mounted face up or sideways. If they were faced down the heat woudl be send out the heat sinks then it would rise back into the amp itself so it would probably get fairly hot.
however, i think it could be done with the right cooling setup i just wouldnt risk it unless you really have to
Old Feb 1, 2004 | 04:43 PM
Car: 89 Camaro RS
Engine: 305 TBI
Ya, that's what I was wondering.. I could add cooling fans.. to blow accorss the heatsinks.. I was just thinking of mounting them under the locking rear storage lid..
Old Feb 1, 2004 | 04:50 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
ive had mine mounted upside down for the past year, hanging under a cover over the rear well, with my sub aimed toward them,
havent had any problems yet, only overheated once, but it was about 110 outside and suck in traffic, it was friggen hot,
Old Feb 1, 2004 | 05:30 PM
Car: 89 Camaro RS
Engine: 305 TBI
Thanks irocbarry, perhaps with some small fans.. they might not over heat for me in the summer.. plus the sub would not be pointing at them, but would be in the area.. perhaps I could position a port on the box I'll be making to semi point towards the amps.. that would help keep em cool..
Old Feb 1, 2004 | 05:32 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
if you used a small cooling fan i dont think there would ever be a problem, mine are sealed around them, with ony the sub reserculating the hot air and there are no problems, if your sub isnt pointing at them i woud recomend a cooling fan, but it might work without one
Old Feb 1, 2004 | 10:44 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
i think it really depends what amps you're using aswell
i would suggest using two fans and pointing them in different directions, one blows cold air in the other blows hot air out
Old Feb 1, 2004 | 11:58 PM
Car: 89 Camaro RS
Engine: 305 TBI
What about mounting one of the fans in the lower part of the rear panel where the spare tire is.. since it is a air flow zone.. It could pull in air from there.. and the air would then be vented out on the other side..
Old Feb 2, 2004 | 09:50 PM
Car: 91 Firebird
Engine: 305 TBI
I know of a couple of people with thier amps mounted upside down and never had a problem.
As for the cooling fans I think thats a good idea no matter what or by a amp with a cooling system built in like my amp.
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
FormulasOnly
Sep 6, 2015 10:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
