how could this be done?
Old Feb 5, 2004 | 04:55 PM
Kandied91z's Avatar
material wise what basically is done to achieve this. it looks to be molded but it's hard to tell. i also really like how the seatbelts are coverd and the look is completely gone. how could you go about doing that with the plastic as it doesn't look like fiberglass?
Old Feb 5, 2004 | 05:05 PM
LUVmy92's Avatar
Car: Camaro
It actually looks like fiberglass to me??? How else would you mold the sides like that with no seam going all the way across? It could be done with plastic but think about the size of the machine it would take to mold a part that big. I worked in plastics and can tell you I doubt it is plastic if it is solid! The machine to mold that would be bigger than a semi trailer, which equals massive expense!. Looks lke custom glass for the covers which wouldnt be difficult to get made. I could be wrong but Im going by a picture!
Old Feb 5, 2004 | 05:08 PM
Kandied91z's Avatar
that's all i'm asking for is your opinion, the only reason i don't think i'ts fiberglass as the stock pannels seem to still be there although i suppose it could have been recovered in glass to make that appearance.
Old Feb 5, 2004 | 05:10 PM
Kandied91z's Avatar
Old Feb 5, 2004 | 05:27 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
maybe he glassed that box and sanded the panels down smooth and then painted them to match.?.
Old Feb 5, 2004 | 05:30 PM
Kandied91z's Avatar
there is to many seams that typically wouldn't be done with fiberglass but anything is possible. i would assume a color with some sort of clear would have been used but maybe that wasn't the intention....it looks like a material of some sort to me but that's just my opinion as it is molded so clean it's a great possibility.
Old Feb 5, 2004 | 06:29 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Maybe he used some kinda combination of fiberglass and a type of bondo?
Old Feb 5, 2004 | 10:17 PM
85TransAm406's Avatar
Car: 1985 Trans Am
he could have texture coated it, which is like a thin coat of rubber or body filler that lets you use a reverse textured material to lay on it to get a plastic like texture.
Old Feb 5, 2004 | 10:56 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
I have done quite a few custom installs and I would say that the box is made out of MDF then Glassed. Indicated by the seems that are visable, the amp rack part I would say is also made out of MDF and Glassed and or Bondo to Mold them togeather. Well that is how I would do it. That is a Lot of work to get such clean results as those. The fiberglassing is easy the bondo is easy the Measuring and sanding and measuring and sanding to complete a project like that is very time consuming. I did a custom install for a friend and we covered the MDF with Automotive Leather And it will give it a nice textured.
Old Feb 6, 2004 | 01:54 AM
Kandied91z's Avatar
where can automotive leather be found?
Old Feb 6, 2004 | 06:03 AM
LUVmy92's Avatar
Car: Camaro
However he did it that is one sweet *** setup for sure! You got something planned Kandied? Looks like your looking for ideas, well if you put a setup like this in yours it will be even more bad ***!:hail:
Old Feb 6, 2004 | 06:45 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Mold the fiberglass into the stock panels, smooth the stock panels, then texture the entire thing, probably with vinyl.
Old Feb 6, 2004 | 09:32 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Here are a Few Links to different companies for coverings.
http://www.autoleathers.com/HTML2/AL.MAIN.FS.html
and for those who would like to cover panels in carbon Fiber or Carbon Fiber/Kevlar blend Go here they sell the kits do cover almost anything. If ya do want to learn how to do it you can send the items to them and they will cover them for a fee.
http://www.kwperformance.com/products.html
Like Jim85IROC said try vinyl it also has great results and isn't as expensive as Leather!!
Old Feb 7, 2004 | 03:47 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
It is difficult to tell, it could be textured fiberglass (seems proabable), or someone has some good experience and access to plastic materials, OR it's very tightly covered in vinyl. I think the simplest way to achieve that look would be to make a bad-ace setup like that, then lightly texture it and paint to match. Or leave it smooth and put a nice finish on it - either way, that setup blows me away - SUPER DUPER Clean on that one
Old Feb 7, 2004 | 04:39 AM
Kandied91z's Avatar
yes i wish there were some better detailed pictures.
very sharp...
