Where to buy ports?
Where to buy ports?
I am going to build a box for my JL15W0 but I am having a problem finding a port that fits their specs. They call for a 5" diameter x 14" length port. I haven't been able to find one that would work at all.
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
you try home depot yet? PVC works from what i hear.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
I wouldn't suggest using the pvc as a port, not because how it functions, but that without a flare on each end of the pvc, it will create turbulance around the entry and exit way of the pipe, and also create wind noise, which isn't what you want. Parts express has some really nice ports, check them out at
www.partsexpress.com
that has to be the most confusing website ever... can you find a direct link?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
can someone show a pic? im not sure what you mean by a flared port.
Yeah I never tried that with wood before but sounds like it could have a good end result when finished. A flared port is like a rounded port, that smoothens out airflow and increases the airs velocity at the edges. By doing this it makes the port more efficient and can boost dbs in many cases, but most of all it all but eliminates port noise, which sucks! I tried to get a link from parts express when I wrote this, but there site was done, internal server error.
Heres a flared port from lightning audio, available from crutchfield.
Originally posted by stiers
I would like to see what a wooden flared port looks like.
Here's an article that shows it:
http://www.speakerbuilder.net/web_fi...ut/porttut.htm
The only thing that article doesn't show is that you can do the same thing on the back side of the port with the internal brace.
do those ports run very expensive? whats the best place to buy
im lookin for a 3x8 port. can somebody help me find one.
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
hi
how do you make a square port, i know if i had a round port it has to be 3 inches wide and 8 inches long for my specific use, how would i make it into a square port, i could use the left over wood ill have, but how do i make the squre port area = the round port area, will i have to do my math hw from high school again?
Car: 83 z28
Engine: 300hp 355
Re: hi
http://www.carstereo.com/help/Articles.cfm?id=31 if you go here and go to the second calculator "calculate vent length" if you put in your box specs, desired tuning frequency, and the outside dimensions of the port you would like to use it will calculate the length for you
dont forget to click on to square ports
Car: 1987 Trans Am
Engine: LG4 305 w/emissions & A/C delete
Transmission: "...check!"
Axle/Gears: it's crap...they're stock!
Re: PartsExpress
I'm glad someone said it before I did! My fiancee's cousin just did a box with 4 ports from PE, and they're actually pretty d@mm good!
-G
-G
mrestrictrplate
Sep 21, 2015 11:24 AM
toronto formula
Sep 10, 2015 07:31 AM
