How loud until speakers distort?
Old Feb 6, 2004 | 11:55 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
I got my Deck and speakers installed last nite.
I did the wiring good, Deck installed easy.
Its a Clarion DXZ535, and I got 2 4x6's, rated at 50 rms each. The deck puts out 17 rms x 4.
After my Volume hits about 21-22 the speakers start to distort. Is this normal, or did I wire them wrong? Why would they distort if I'm only putting less than 1/2 the watts they can handle. And if I get an amp to power them, will they go louder and cleaner?
Thanks, Joe
Old Feb 6, 2004 | 01:15 PM
Daishi's Avatar
ok NVM this post, One of the wires had pulled outta the little clip thing and was only touching with like 2 strands, seems better now
Old Feb 6, 2004 | 02:00 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Even still, there's no specific spot where speakers start to distort. The "21 or 22" spot on your deck doesn't mean anything. That's just an arbitrary number.
Things start to distort for a million reasons. If you have a problem, as you've found, you can have distortion. If you overdrive anything within the signal path, you'll get distortion. If you overdrive the speakers, distortion. Even if you don't obviously overdrive the speakers, as you give them more power, a lot of speakers can become very harsh, due to many different reasons.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
loud91rs
Oct 5, 2015 10:05 PM
codeysabatini
Sep 20, 2015 11:36 AM
