Getting power from the fuse box
Old Feb 16, 2004 | 08:36 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey would it be hard to get constant power from the fuse box? This would be for interior neons and a switch would be hooked up.
Old Feb 16, 2004 | 08:58 PM
9177's Avatar
not hard but you would probably be better off with running a wire from the battery.
Old Feb 16, 2004 | 09:13 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
x2
The fuse box isn't the best place to tap for power. It depends how big of neons you're getting, what gauge wiring you will need, but once ya know that much, I'd suggest tapping off the battery, MAKE SURE you have a fuse in there (fyi: Fuse is a safeguard. If you would have a problem with the wire, and it was catch fire/short, it would only reach the fuse, the fuse would blow, thus ending the circuit), go thru the firewall, to a relay switch, and then to the neons.
Old Feb 16, 2004 | 09:25 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The neons are no longer then 2 ft, and right now they plug into the cigarette lighter. We would like a cleaner look, and have the power to turn it on and off with a switch.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
backtothe80s
Sep 5, 2015 12:39 AM
stalkier
Aug 13, 2015 12:59 PM
