yellow power wire has no power
Old Feb 22, 2004 | 01:09 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
this is really confusing me, and i have spent enough time tracing wires to find out what is wrong with this thing, hoping someone on here can help.
it is a 91 bird and the yellow wire is the constant 12v+ for the radio, except it has no power to it, the fuse in the fus block is fine, and someone had mentioned another fuse block near the radio pod but it did not have a fuse for the radio, or atleast i could not see one
anyone got any ideas ? personally i think it is a bunch of
Old Feb 22, 2004 | 04:08 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Why not just run a new wire from the battery, thats what I did.
Its a lot easier than tracing wires
Old Feb 22, 2004 | 06:18 PM
Aqua FBody's Avatar
Car: 95 Contour GL 03 KIA Spectra
Engine: 2.0 Zetec 1.8
Transmission: MTX-75 5spd
In my car the yellow wire goes to the ingition switch
Old Feb 22, 2004 | 09:02 PM
Car: 91 formula
Transmission: t5
i rather get it working the right way instead of adding more wires, whoever owned this before be liked adding garbage wiring so i am trying to get it all out and get everything working correctly....
Old Feb 22, 2004 | 09:59 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Hmmmm.. Yellow wire is the keyed 12 volts for me. Constant is orange/black. But then again I have an 89 Camaro. don't know if any differences between birds & maros & years.
Old Feb 23, 2004 | 03:02 AM
racerx7's Avatar
Car: rx7, wrx, rx-2
Do you have the factory wiring diagram?
If so, post it up and I will look at it for you.
I would hook up a (power probe/test light/
volt meter) and check both sides of the fuseblock to see if it had B+.
If you don't have b+ on either
side of the fuse, the problem is up
stream. You will have to trace it
or get a factory wiring diagram.
If B+ on only one side either the fuse
is bad or the connection to the fuse
block.
If you have B+ on both sides then:
++ fuse is good
++ power to fuse block is good
bad connection from from fuse to
your radio then.
If you have b+ on only one side, then
check the fuse. No I don't mean just
look at it. Hook up your volt meter
and make sure it is ok. Sometimes
it is broken where you can not see
it. Or the gheto/fast way put
in known good fuse and then
see if you b+ on both sides.
good luck.
Old Feb 23, 2004 | 06:40 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
tap into your cig lighter. Its right next to there anyway.
Nate
Old Feb 23, 2004 | 09:08 AM
Car: 91 formula
Transmission: t5
i should probably get a volt tester that woudl probable help a whole bunch
Old Feb 23, 2004 | 09:13 AM
Car: 91 formula
Transmission: t5
sorry i got confused, it is not the yellow one it is the orange one, i thought it was the yellow, but it is the orange because it is the constant 12v+ wire, what one is the one that goes throught the fuse box, the 12v+ constant or the switched one ?
Old Feb 23, 2004 | 12:25 PM
Car: 89 RS
The yellow wire(switched +12 volts) runs to the radio fuse in the main fuse box. The orange(orange/black for mine)wire is constant +12volts & is fused in that separate pull down fuse panel by the gas pedal. This is from my personal experience with the same prob. And according to my wiring diagram 89-91 should be the same wiring. So your's & mine should be the same unless birds have slight differences than maros
Old Feb 23, 2004 | 12:29 PM
Car: 89 RS
hey white91formula, I just realized I'm trying to help you out in 2 threads on the same prob
Old Feb 23, 2004 | 05:51 PM
Car: 91 formula
Transmission: t5
it is the orange one that i am having trouble with, and therei s no fuse for it on the pull down panel
Old Feb 23, 2004 | 08:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The orange wire runs to the accessory fuse.
Old Feb 23, 2004 | 09:11 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
its the accesory fuse.
If its all scewed up, do what I do, run a new wire, you may be never close to the right wire, you could end up cutting the wrong one, that why I think it's better to run a new wire, unless your planning on keeping this car forever
Old Feb 23, 2004 | 10:38 PM
Car: 89 RS
Ok I just talked to another guy who has a 91 Camaro. Try double checking your fuse box for one labeled just arc. Like I said mine was on the convenience center & labeled arc radio. Found out that only applies to 85-89. 90-92 has it on the main fuse box & is labeled arc. If that isn't it then sorry. I'm really trying to help you solve this
Old Feb 24, 2004 | 06:09 AM
Car: 91 formula
Transmission: t5
thank you all, i will check that later today wen i get home from wrok
Old Feb 25, 2004 | 08:50 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
no the fuse is labeled ACC
Old Feb 25, 2004 | 09:07 PM
Car: 91 formula
Transmission: t5
ok i found it, it was the arc fuse, not the acc fuse
i had checked that one before and i thought it was fine, but i am just glad that i haev found it and fixed it and it is out of the way.
Old Feb 26, 2004 | 12:48 AM
Car: '81 Trans Am
Engine: 6.6L
ok sorry must be just for camaro
Old Feb 26, 2004 | 07:00 PM
Car: 91 formula
Transmission: t5
i am not trying to be rude, but it is for the camaro's also, the arc fuse is the fuse for the constant 12v+ wire for the radio, the acc fuse controls all accesories, including power to the radio, which i know believe goes through the arc fuse after that. so in a sense you are right, but there is j ust another fuse after the acc fuse
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
