Which amp to go with this sub
Subscribe
Mar 4, 2004 | 09:05 PM
ED
Driver Name : e10Kx.44 /x .14
Voice Coils : Dual 2 or 4 ohm
Power Range : 150/400 watts
Applications : Sealed / Vented
I am pretty sure the power range is 150-400 w rms, since the eD site recommends a 400wrms amp. That said, I like the JBL amps and amp trying to decide whether to get the 300.1 or 180.2 The 300.1 is $20 more at sounddomain. I like the idea of having a dedicated amp for the sub, however, having the option to power 6x9's eventually is a plus. Ohm load isn't too much of a consideration, since the sub can be wired for just about any situation. With the 180.2 I will get more power, the 300.1 has "power supply switching technology" however which is supposed to reduce the drain on the car's electrical system.
Reply 0
Mar 5, 2004 | 01:32 AM
Get the best quality amp you can afford thats in the subs power range or a litte over.
You'll never get a strainght answer on these boards anymore.
Seems like everyones into brand bashing these days.
Reply 0
Mar 5, 2004 | 02:36 PM
Re: Which amp to go with this sub
Quote:
sounds like the 300.1 is a class D amp, which are more effecient. But its not a super powerful amp to begin with so i think your electrical system would be fine with a class a/b of that same power
Reply 0
Subscribe
