Orion HCCA 225 Qs
Old Mar 9, 2004 | 05:00 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Orion HCCA 225 Qs
I have 2 orion xtr3 dvc subs and the orion hcca 225 and would like to know if anyone has the manual. I hear the amp is .5 ohm stable right know i have it wired one sub on each channel with the vc in parrallel any help would be great. btw the amp is about 5 yrs old. thanks
Old Mar 10, 2004 | 10:01 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
that amp is a f*cking monster.
Just make sure you have adequate ventilation for the amp, then parallel wire the 3 subs. If those subs are dual 4 ohm coils, you can get a nice 1 ohm load for that amp.
Old Mar 10, 2004 | 04:01 PM
seiplentz's Avatar
Car: 85 Z28
Yeah the amp does vibrate my car to death but I want more power if I can get it and I have two dvc subs 4 ohm. Right now the 2 amps I have are mounted on the floor under the box in the cargo compartment I built the box leaving room there for the amps so they wouldnt be seen. Think I should put a fan under there as well or maybe a port hole in my box its completly sealed now dont know if the subs are meant for a ported or sealed enclosure. Orion XTR3 subs
Old Mar 11, 2004 | 12:13 PM
Jim85IROC's Avatar
just porting a previously sealed box won't help anything. It'll just make a sloppy sounding mess.
The volume requirements for a ported configuration are much different (larger) than the same sub in a sealed setup.
kammi10
Nov 9, 2015 08:28 PM
the_hamturdler
Sep 30, 2015 12:50 PM
corey8084
Sep 17, 2015 02:56 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
